0 members (),
129
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26599 11/26/2004 1:41 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | My favorite way to remove bearing races is to weld a thick bead around the inside where the bearings ride on the race with a wirefeed welder. This does two things: it destroys the temper and loosens the bond between the axle tube and the race, and it shrinks the race because the bead shrinks as it cools, pulling the bearing in with it. It should just about fall out. It takes much less time than the other methods and is safe as long as you don't spatter too much. It also doesn't heat the axle tube much, most of the heat is concentrated at the bearing. I pulled one out of an aluminum BMW control arm this way.
