| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24791 01/22/2002 5:31 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Does this thing have the park brake on back? The drum for it and another one inside to keep grease off the brake from U-joint can "ping" if something is loose hitting it. Like the return spring, Or, string/wire or anything hooked on joint and flying around hits it until it goes too fast to hit and stays straight out. Or metal or pc in driveshaft, rolling at slow speeds, staying out to outside when spinning harder. Clutch arm spring not tight? Arm rattles around.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
