Weeds, take your time. You are a long way ahead of me. I have had a set back (my feet) for a while but doing good now. Just last night I started wringing off the bolts that holds the back of the panel to the rear chassis crossmember. I did look at the plywood and mine is a one piece deal. I may do as someone mentioned above and lap a joint in the middle and hide it with the bed strips. As I looked around under it I said Man O Man look at all the bolts that are bound to be a "pain" to get out. But at least I'm making progress and getting it stripped down. All is off the front and next is the running boards and rear fenders. A few mounting bolts and that sucker will be ready for the sand blaster while I blast the chassis. Whew! I have a digtal camera and if my daughter and future son in law will help me set up I to will have some pics that folks can see. In the meantime I am gathering parts, blasting, priming and painting the little stuff. More later.
