| | | Forums66 Topics128,269 Posts1,058,399 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | Double check the block casting number. The number given may not be a valid number. Sometimes the digits in these casting numbers are hard to distinguish. The closest number I've found is 3921968, which would be for a 64-76 230 or 250, according to Inliners. The casting date of E208 would then translate to May 20, 1968.
The given numbers by the distributor do not follow the usual engine series number format. We're these the numbers stamped into the pad just aft of the distributor? This could have been a replacement engine.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
Entire Thread
OK,Still confused on engine #s
| jeffs 52 panel | 04/18/2006 1:24 AM |
Re: OK,Still confused on engine #s
| Achipmunk | 04/18/2006 10:05 PM |
| jeffs 52 panel | 04/18/2006 10:20 PM |
| Baldy | 04/19/2006 12:20 AM |
| jeffs 52 panel | 04/19/2006 4:07 AM |
| jeffs 52 panel | 04/20/2006 7:59 PM |
| Builder | 04/20/2006 8:53 PM |
| Achipmunk | 04/20/2006 9:14 PM |
| Achipmunk | 04/20/2006 9:19 PM |
| Chester | 04/20/2006 9:46 PM |
| Chester | 04/20/2006 9:48 PM |
| Chester | 04/20/2006 9:51 PM |
| Xram53 | 04/21/2006 7:13 AM |
| packhorse32 | 07/02/2006 10:43 AM | |
