| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Yep, You can get the bracket from JC and bolt them in. You will need to drill a couple of holes in the door jam and the bracket. The bracket goes on the inside of the door and there are two tabs that stick through the slots in the door. These tabs have a hole in them that a pin drops through to attach the door check. That's what I did with one of mine when I discovered it was missing after everything was painted. Hope this helps George | | |
