1 members (Rnl364),
104
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | I'm missing the door check that keeps the door from swinging open too far! The problem is the bracket that secures the check on the door is missing. I bought the door check from Jim Carter, and know they have a weldable bracket. I notice two tiny slits on the door like the orginal it must have had two tabs that bent inside the door, I really don't want to weld on the door if I don't have to.
Is there a solution to my problem? Where can I find an originnal door check?
Dan | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Yep, You can get the bracket from JC and bolt them in. You will need to drill a couple of holes in the door jam and the bracket. The bracket goes on the inside of the door and there are two tabs that stick through the slots in the door. These tabs have a hole in them that a pin drops through to attach the door check. That's what I did with one of mine when I discovered it was missing after everything was painted. Hope this helps George | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | Dumb me I didn't think about running two screws or bolts through the plate! the funny thing is there are two slots in the area the original plate was at giving me the idea they had tabs that fit into the door and you twisted the tab to secure them. Why did JC make them weld or bolt on?? It reminds me of the tabs that hold the Stainless Steel decorative strips on the hood. I'd prefer not to drill any holes, but it's better than the weld on idea on my paint!
Thanks for the great idea. I'm not in a hurry and hope someone can shed some light about the original unit with the tabs and where it can be bought!
Dan Mascheck Wharton, TX | | | | | | Anonymous Unregistered | | Anonymous Unregistered | The one Jim Carter has was made off an original one taken off a door, They were originaly spot welded on. I would think if you just twisted a tab on the inside of a slot in the door after awhile with enough bumps and pulls from the check strap it would straghten and pull back thru. just my .02 | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | I'm sure you are right, but I don't notice the tack welds on the passenger side door, and the driver side has no check bracket and there are two horizontal slots, which I assumed were used with tabs to secure the check. Seems a bit odd, but I need to look closer on the one that is complete on the passenger side! When I get the truck repainted I’ll get them to tack weld one on, but I don’t want to do it now! Thanks, Dan Mascheck Wharton, TX | | |
