0 members (),
44
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Richard,
That is a higher compression 235 head that I think first became available in 1956 (and it might have been used through 1962). It will work on any 235 block from 1954 onwards (with some minor modifications needed to the rocker-arm oil feed line/tube, depending on the year of the rocker arm assembly). It can also be used on 261 blocks but needs additional holes (between the paired cylinders) for adequate coolant flow.
See if you can find the engine serial number (pressed into the block to the rear of the distributor) and the block casting number (at the upper right of the starter).
Tim | | |
