0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I used the $95. Cpp 5 lug basic bracket kit on my 54-3100....They furnish the brackets, bolts, and required spacers, and info on what you need to purchase locally. You'll use mid-70's Camaro rotors and will need to get the CPP $30. bearing conversion kit. They have detailed instructions on their website. You can check locally for the cost of mid-70's rotors, calipers, brake hoses and brake pads.
The lower end of the disc install is the cheap part. I fabricated my own master cylinder bracket, used a mid 70's Corvette manual disc/disc master, Wilwood adjustable proportioning valve from Summit for $39.00 and 2 residual valves for $16.00 each. With a roll of 3/16 line material and brake fluid it came to about $375.00. If you had to buy the bracket it would be another $79.00.
I am running a 5 lug Camaro disc differential and with 4 wheel discs you don't need power booster. I've got power on my hot rod truck and they are too twitchy. The Wilwood adjustable proportion valve is a must as I've yet to see a kit valve that matches your vehicle and driving conditions....and they are sometimes a bear to get bled properly. I can adjust my brake bias from inside the cab behind my right foot.
If you can do the plumbing by yourself you'll send an hour tearing out the old stuff, 2 hours at AutoZone trying to find someone who knows a rotor from a caliper, and about 6 hours getting everything else plumbed in. I made all my lines and started with a fresh system. Upgrading to a dual master with old lines, solid and rubber, is going to bite you later on down the road.
Was it worth it? You betcha!!!! She'll stop on a dime (figure of speech) haven't run over a Ricer since I upgraded and recommend it as the first upgrade you make before you hit the road. I've got some pics in my album. Hope this helps. | | | |
Entire Thread
Disc Brakes, Cheap
| OKSoda | 09/05/2006 8:53 AM |
Re: Disc Brakes, Cheap
| NM51 | 09/05/2006 2:27 PM |
Anonymous
| 09/05/2006 2:57 PM |
| Apache Kid | 09/05/2006 3:41 PM |
| bluedot38 | 09/05/2006 4:09 PM |
| Fort Knox | 09/05/2006 4:13 PM |
| 41Chevy | 09/05/2006 6:17 PM |
| Rick Rickard | 09/05/2006 9:07 PM |
| bluedot38 | 09/06/2006 6:09 AM |
| bessie | 09/06/2006 9:27 PM |
| OKSoda | 09/06/2006 9:32 PM |
| Tab | 09/06/2006 11:09 PM |
| chevman32 | 09/07/2006 5:40 PM |
| bluedot38 | 09/07/2006 6:02 PM |
| Tab | 09/08/2006 4:40 AM |
| Racecarl | 09/09/2006 2:04 AM |
| bluedot38 | 09/10/2006 12:00 AM |
| Fla54Chevy3100 | 09/10/2006 2:44 AM |
| john romero | 09/10/2006 7:44 PM |
| chevman32 | 09/11/2006 2:02 AM |
| Utah Smitty | 10/13/2006 5:19 AM |
| Builder | 10/13/2006 5:23 PM |
| 57 vroom vroom | 10/31/2006 12:42 AM |
| john romero | 10/31/2006 3:54 AM |
| 57 vroom vroom | 11/02/2006 1:04 AM | |
