1 members (wilbur53),
92
2
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20737 05/19/2004 3:54 AM | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | I'm going to use one of the HEI distributors from Langdon's on my engine rebuild. The recommended advance is somewhere around 20 degrees. The shop manual for the 235/261 says to use a timing light and get the flywheel ball to show up at the right time, but I'm thinking that is for a 5 degree advance.
How does one go about setting at 20 degrees for initial setup? Once I get it close enough to run I can just use one of those fancy timing lights to get exact.
Thanks in advance.
shoeless | | |
