0 members (),
110
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,196 Posts1,057,394 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20737 05/19/2004 3:54 AM | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | I'm going to use one of the HEI distributors from Langdon's on my engine rebuild. The recommended advance is somewhere around 20 degrees. The shop manual for the 235/261 says to use a timing light and get the flywheel ball to show up at the right time, but I'm thinking that is for a 5 degree advance.
How does one go about setting at 20 degrees for initial setup? Once I get it close enough to run I can just use one of those fancy timing lights to get exact.
Thanks in advance.
shoeless | | |
#20738 05/19/2004 8:10 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | if you have a mark that's 5 degrees, and a TDC mark, then 20 degrees would be back another 3 spaces of the distance from TDC to 5 BTDC, i.e. 4 5 degree intervals would be about 20....
to me this sounds like a WHOLE LOT of advance. My supercharged lincon only got like 12 degrees, but hey, what do I know, it could be a difference in how the distb is set up and how it delivers spark. | | |
#20739 05/19/2004 3:58 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | It sounds like he's talking total advance, which is the combined vacuum and mechanical at speed. I know how to set it with a degreed balancer and the correct timing light, but not on an engine without those luxuries.
Call Tom and be sure, he'll shoot straight with you.
Fred 52 3600 69 C-10
