You can get the rubber grommets at most parts stores as well as the twist on type oil caps. The "indentations" are for a twist on type oil cap or breather. You can also buy rubber plugs to fit the holes in case you wanted to block one off if you use a twist on type breather instead of an oil cap.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
