8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert), 94 guests, and 2 robots.
Topics128,052
Posts1,055,716
It's been a while since I've done this, and I can't even remember how this works...here's the question
My valve cover is cracked, so i'm getting some new chrome ones, and here's a pic of the ones I got.
http://images.channeladvisor.com/Sell/SSProfiles/30057804/Images/9518.jpg
So, on one side, there's 2 holes (1 for Oil, 1 for crankcase breather) and on the other, there's 1 hole, for what???
And secondly, How is my oil cap going to screw onto that? Is there some kind of adapter, like a short pipe, for the cap to go on?
Thanks guys
edit: after studying that picture for a minute, I noticed that the oil hole has some indentions, that may be the spot for the cap to screw onto...double-check me on that smile
GO RANGERS grin
Photos Updated so check them out!
I'm betting the PCV valve goes into the extra hole. Just make sure it's on the opposite side from the crankcase breather.
Hope this helps
Willy
1947 Chevy 6400 Wrecker
Old Stovebolts don't leak oil
They just mark their territory
Willy's right on the money the pcv valve goes in a rubber insert which fits in the hole.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
You can get the rubber grommets at most parts stores as well as the twist on type oil caps. The "indentations" are for a twist on type oil cap or breather. You can also buy rubber plugs to fit the holes in case you wanted to block one off if you use a twist on type breather instead of an oil cap.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
Look inside of the holes. If your aftermarket chrome covers have baffles, then be cautious when you add oil! The baffle will severely restrict how fast you can pour oil into the engine. Most folks remove the baffle under the oil filler hole...
Dano
my truck gets better every day...every PAYDAY smile
Z
Z Offline
i use an automatic transmission funnel.i can dump the whole can of oil in it and let it seep in.
Great idea with the tranny funnel! I remember way back when I bought a set of chrome covers and nobody mentioned the baffle...I dumped a whole quart down the side of my engine! :mad: I thought if I could save someone else the trouble, that'd be good!
Dano grin
what does pcv stand for also. you can get all the parts you need from hotzoneperformance I got myvalve covers from them and they have all that kind of stuff
On a later model V 8 (post 60 or so), you only need one hole in each side. One side with a vented oil fill cap and one side with a pvc (positive crank case ventilation – a fancy word for “your carb helps suck air through the engine”).
The idea is that your carb sucks on one side drawing air through the vented cap on the other, keeping the engine from building internal pressure…
T-rav, PCV stands for positive crankcase ventilation.
