Okay, Ive got a 53 w/original 216 and carter yf carb. It drove fine for 2 weeks, sat in the garage and now wont keep up on the road. She stutters like she aint gettin enough fuel and I dont hardly get her into 2nd gear frown .
So, I rebuild the carb and clean it out, as well as a home mechanic can... Ive replaced the fuel pump, the original was fuel of tarry old gas. I blew out the fuel line, no rust. I look in the tank when replacing the sending unit-(which wasnt the problem with the gas gauge not working grr...)no rust there. Clean fuel filter. New wires and cleaned the plugs.
Now the odd part. The bottom of the carb where it bolts to the intake, is freezing up. Pulled it off looked for pinholes, cracks etc(nothin I could see), used a little rtv sealant on both sides of the gasket just in case, still freezin up. Idles pretty good. Runnin a little rich.
Im about to break somethin, save me form doing this as it probably wont be a good thing :mad:
The only thing I can think is the diaphram for the vacuum advance on the distributor is leaking? I rubbed water on the fittings. Nothin.
Any ideas Im all out. Thanks, Jeff
Oh yeah I know its gonna be somethin so stupid to...
My 1953 Chevrolet
1947.1 Gallery
1972 C-10 1/2 Ton & 1972 C-30 1 Ton
