| | | Forums66 Topics128,031 Posts1,055,435 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20257 07/16/2003 8:00 PM | Joined: May 2003 Posts: 22 Junior Member | | Junior Member Joined: May 2003 Posts: 22 | I have a very thin reddish fluid leaking from the right rear hub. I found it when I took the right rear tire off to find out why the brake were grabbing. It appears that its coming from a large hole in the hub. It doesnt have the look or smell of gear oil. Is it possible that its brake fluid? Doesnt look like the wheel clynder is leaking tho the brakes wouldnt return and grabbed alot and the wheel cyl wouldnt adjust. If it is a axle leak do I have to tear down the axle to fix it? I was planning to put the ring and pinion gear set that patricks sells in down the road.
Thanks | | |
