| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | One of the tricky parts will be adjusting the E brake cam. You should definitely have the factory manual for this. The springs may be hard to come by, maybe Jim Carter would have them. There are retainer clips on the pins that hold the shoe assembly together. These are difficult to find new so if you can save them, that would be a good thing. Some of us believe that a C-clip of the proper size would do. Also if your E Brake cables are seized, you will need to free them. There are ways of doing this.
I don't understand the comment about the hub seals. The drums should come off with the hubs in place. | | | |
Entire Thread
HELP, ADVICE NEEDED 3/4 TON BRAKES
| sam49chevy | 07/08/2005 7:57 AM |
Re: HELP, ADVICE NEEDED 3/4 TON BRAKES
| Fumblin46 | 07/08/2005 9:11 AM |
| V6 jimmy | 07/08/2005 11:10 AM |
| Fred T | 07/08/2005 2:33 PM |
| truckernix | 07/08/2005 3:49 PM |
| p.j. | 07/08/2005 5:46 PM |
| sam49chevy | 07/10/2005 5:48 AM |
| Bart | 07/10/2005 11:54 PM |
| Highflyer | 07/13/2005 1:33 AM |
| Tab | 07/14/2005 5:30 AM |
| sam49chevy | 08/03/2005 7:30 AM | |
