I guess you've already checked your ground connection to the circuit. In my opinion,90 % of the electrical problems on these old trucks can be traced to one of two things;butchered wiring or weak grounds. If the wiring appears to be good,my first move would be to test for a bad ground. If it isn't the ground,I'd check the power wire for the gauge,it might have a connection that's nearly broken. If that isn't the problem,I think I'd change the sender. Just an idea...
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
1952 Chevy 6400 dump bed project truck
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
