| | | Forums66 Topics128,115 Posts1,056,633 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17001 05/25/2004 4:18 AM | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | I've used the ATF method before with good luck. On my last one, I mixed in marvel mystery oil too. The engine runs without changing rings.
Fill up the cylinders and wait a while. Try it every couple days. Soon you will be running again. Good luck!! | | |
