3 members (Gdads51, 2 invisible), 60 guests, and 1 robot.
Topics128,115
Posts1,056,636
Members48,450
Junior Member
Junior Member
We have a 302 that has been sitting a while so we took the head off and it looks pretty stuck but not all rusted walls have a light rust but are smooth what is the best way to unstick this sucker?
Thanks Mark and Nick
One of the ways I've heard of, is to pour some Marvel Mystery Oil in the cylinders and let it soak. Probably do the same for 2 days or so, while trying to turn it over each day. I know some of the other people on here have their own way of doing it. Maybe they'll chime in later. Good luck. John
1968 Chevy C-10, 250 and 3 speed on floor, Hedman headers, Offy intake, Edelbrock 600cfm 4 barrel, HEI
1966 Chevy C-10, motor and tranny went into the '68. Waiting to be restored.
some times if you have the head off you can take a short 4x4 post and a big hammer and beat them lose but some times its a littel hard on the rings
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
Red dot, center of chest ...
The oldtimers used automatic transmission fluid for this. Just pour it in the cylinders and let it soak for a while.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
I've used the ATF method before with good luck. On my last one, I mixed in marvel mystery oil too. The engine runs without changing rings.
Fill up the cylinders and wait a while. Try it every couple days. Soon you will be running again. Good luck!!
Junior Member
Junior Member
PB Blaster is best but ATF works great. I just got a 2.5 that is stuck. Used PB and in a few days it was moving, but only about 45 degrees. It had water (gallon or so) in the crankcase so it is tough to get. I started filling the crank case with all my used oil and ATF (used cause the engine is probablly bad) and plan to fill it to the top and let it sit for quite a while to see if it will loosen up.
There is no mechanical problem so difficult that it can not be overcome by brute force and ignorance.
