Heat and a dead blow hammer. Inspect the bottom of the shafts for wear. It's possible to turn the shafts upside down and drill new oil holes with a solid carbide drill bit. Plug the upper holes with short pieces of round brass rod, tapered to be a snug fit in the holes with a drill press and a file.
