| | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Just remove the valve cover and attach two pieces of chain to the rocker arm stands with clevises and angle iron. then lift with the engine hoist. I've been lifting fully dressed engines, bell housing, flywheel, clutch, and all, that way for 50+ years. Haven't dropped one yet! However, that Daytona stand is plenty strong to support the assembly from the bell housing. Bolt a piece of angle iron from the front of the engine to the floor with a caster wheel attached if the overhang is worrisome to you. Jerry
