| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 6,696 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,696 | I know the side cover uses a gasket. A friend suggested using a gasket maker but I want to make sure whatever I do lasts.
Ol' Roy's engine side cover is seeping oil all along the bottom flange and the valve cover also has leaks toward the rear. I intend to replace the valve cover gasket and adjust the valves while I'm in there.
This is a 1951 216 with the 2-bolt valve cover. Do the bolts have rubber seals under their heads?
When I'm ready to adjust the valves, I'm sure I'll have some questions about the paired cylinder method but in the meantime I want to get the proper parts and supplies assembled for the leak repair. I also intend to paint the parts while they're off.
There are a couple valve cover gaskets available: Mahle / Clevite - 7/32" = .22", Victor Reinz - 5/32" = .15" , FelPro - 5/32"
I'm inclined to go with the thicker Mahle/Clevite gasket but I'll do whatever you guys say. I intend to attach the gasket to the head with rtv or similar and just grease the top for easy removal of the cover in the future. Does the extra 1/16" make a difference?
While we're at it, what about the oil pan gasket? The three brands all look about the same except for small differences in price. All are cork-rubber. Felpro Blue Stripe, Victor Reinz, Mahle-Clevite
1950 Chevrolet 3100 (Ol' Roy)
Entire Thread
Engine Leaks, Gaskets, Etc.
| Otto Skorzeny | 09/11/2026 1:18 PM |
Re: Engine Leaks, Gaskets, Etc.
| klhansen | 09/11/2026 5:20 PM |
| Otto Skorzeny | 09/11/2026 5:27 PM |
| Jon G | 09/11/2026 6:09 PM |
| klhansen | 09/11/2026 7:16 PM |
| Otto Skorzeny | 09/11/2026 8:44 PM |
| Otto Skorzeny | 09/11/2026 8:45 PM |
| Guitplayer | 09/11/2026 11:15 PM |
| 52Carl | 09/11/2026 11:46 PM |
| Ponchogl | 09/12/2026 1:43 AM |
| klhansen | 09/12/2026 3:19 AM |
| Otto Skorzeny | 09/12/2026 11:49 AM | |
