Yes - A shallow lip which I think you can see in the zoomed in screenshot from your pic. Be very careful not to grind away or disturb that as the new expansion plug won't be supported properly or seal right if ground away.
Have you tried prying out the remaining plug?
~ Dan
1951 Chevy 3 window 3100
