1 members (LAROKE ),
127
2
robots. Key: Admin ,
Global Mod ,
Mod
Topics128,196
Posts1,057,393
Members48,471
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
I tried to fabricate a bracket to hold the return springs, but later found out I needed to install the engine side pan that holds the Z bracket for the brake return spring and wire extension. My setup now looks like this which I believe is stock. Same spring is used for the brake and clutch. Are there other pictures you need?
~ John in Utah
1946 1/2Ton w/4-speed manual transmission w/1960 235 engine Here We Go Follow in his DITY Bay - If you think about it, it has been one year ago today!
Entire Thread
1936-46 Chevy 1/2 T Brake, MC, and pedal shaft bracket
Ponchogl 03/13/2026 3:19 PM
Re: 1936-46 Chevy 1/2 T Brake, MC, and pedal shaft bracket
Gdads51 03/13/2026 4:50 PM
UtahYork 03/13/2026 6:57 PM
Ponchogl 03/13/2026 8:43 PM
UtahYork 03/14/2026 2:15 AM
Gdads51 03/14/2026 2:39 AM
UtahYork 03/14/2026 3:34 AM
46Sparky 03/14/2026 2:42 PM
Bogart's Truck 03/14/2026 5:28 PM
klhansen 03/14/2026 6:38 PM
Ponchogl 03/14/2026 11:02 PM
Bogart's Truck 03/15/2026 3:34 AM
UtahYork 03/15/2026 6:57 PM
Ponchogl 03/15/2026 10:38 AM
Bogart's Truck 03/15/2026 4:27 PM
Ponchogl 03/16/2026 10:39 PM
