Tronman, thank you for the insight. All of the rear brake parts are new and I suspect that you are correct about the adjustment being different between the two rear drum setups. I am not overly concerned about the side to side difference in the rear at this point as the shoes and pads are far from broken in (about 20 miles total to date).
