8 members (Otto Skorzeny, Paul Mullen, Joe H, 55shaker, greenie-reddy, Steveoreno, Bill Hanlon, KEVINSKI),
83
2
Mod | | | Forums66 Topics128,188 Posts1,057,330 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 2,337 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,337 | Thank you. Yes the pinion bearing screw at the bottom was sticking out farther than the other two but everything was tight. I did have another rear axle to look at and to check the depth and they are in place enough to hold everything in place but was unsure about messing with them. Do you remember what sealer you used I was thinking maybe aviation gasket by permatex. Thank you Kevin | | |
