| | | Forums66 Topics128,202 Posts1,057,409 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2022 Posts: 24 'Bolter | | 'Bolter Joined: Feb 2022 Posts: 24 | So… I have been trying to remove the camshaft… and like a dummy I did not ask or buy a book etc.
So what book should I buy?
Turns out the valve lifters are all stuck in their hole. I don’t want to use channel locks on them to get them out…. Surely that damages them?
Could I use feeler gauges (or some other quite smooth steel) to shove between lifter and cam, then rotate assembly to help push the lifter(s) out a bit more?
(I have them soaking in some combo of wd-40, roil, and pbBlaster for now).
Thanks.
PS: I am sure the machine shop would pull the lifters and cam… but I have never removed a camshaft… so I want to pull it,,, even if I just put it right back in.
62 c10 rebuilding it cheap Family rust bucket 2of2
Entire Thread
235 smoking, blow by, low oil pressure low power
| 62 c10 wally | 08/25/2025 1:01 AM |
Re: 235 smoking, blow by, low oil pressure low power
| Hotrod Lincoln | 08/25/2025 1:27 AM |
| 62 c10 wally | 08/26/2025 8:01 PM |
| Gdads51 | 08/26/2025 9:30 PM |
| 62 c10 wally | 08/27/2025 12:33 AM |
| Hotrod Lincoln | 08/27/2025 1:25 AM |
| 62 c10 wally | 08/29/2025 9:02 PM |
| Gdads51 | 08/30/2025 2:21 AM |
| Hotrod Lincoln | 08/30/2025 2:48 PM |
| Hotrod Lincoln | 08/30/2025 6:49 PM |
| 62 c10 wally | 08/30/2025 8:00 PM |
| KevinS | 09/06/2025 12:52 PM |
| Bill Hanlon | 09/06/2025 2:58 PM |
| Hotrod Lincoln | 09/06/2025 4:00 PM |
| 62 c10 wally | 11/04/2025 9:02 PM |
| Otto Skorzeny | 11/04/2025 9:23 PM |
| Dragsix | 11/04/2025 9:36 PM |
| 62 c10 wally | 11/05/2025 12:24 AM |
| Otto Skorzeny | 11/05/2025 1:27 AM |
| Hotrod Lincoln | 11/05/2025 5:20 AM |
| JW51 | 11/05/2025 3:41 PM |
| 62 c10 wally | 11/06/2025 4:33 PM |
| Hotrod Lincoln | 11/05/2025 11:06 PM |
| Dragsix | 11/05/2025 11:36 PM |
| Hotrod Lincoln | 11/06/2025 4:50 PM |
| BC59 | 11/06/2025 8:58 PM |
| 62 c10 wally | 11/06/2025 10:18 PM |
| Hotrod Lincoln | 11/06/2025 10:57 PM |
| 62 c10 wally | 11/06/2025 11:01 PM |
| klhansen | 11/06/2025 11:02 PM |
| Hotrod Lincoln | 11/06/2025 11:05 PM |
| 62 c10 wally | 11/06/2025 11:20 PM |
| Hotrod Lincoln | 11/07/2025 1:44 AM |
| 62 c10 wally | 11/23/2025 5:16 PM |
| Gdads51 | 11/23/2025 5:31 PM |
| 62 c10 wally | 01/06/2026 10:36 PM |
| 62 c10 wally | 02/11/2026 1:40 AM |
| Hotrod Lincoln | 02/11/2026 1:47 AM |
| Otto Skorzeny | 02/11/2026 3:36 AM |
| Otto Skorzeny | 02/12/2026 10:13 PM |
| Nick in Manitou | 02/12/2026 10:35 PM |
| Phak1 | 02/12/2026 10:46 PM |
| 62 c10 wally | 02/28/2026 11:29 PM |
| Woogeroo | 02/14/2026 8:30 PM |
| 62 c10 wally | 02/28/2026 11:30 PM |
| Gdads51 | 03/01/2026 2:55 AM |
| 62 c10 wally | 04/11/2026 6:28 PM |
| Gdads51 | 04/11/2026 7:50 PM |
| Phak1 | 04/12/2026 12:13 PM | |
