I don't know if your flywheel is on or off truck...but it would be a good idea to count the teeth. Count the teeth for 90 degrees of the diameter and multiply by 4. So you/we can be sure of our advice
Dan's great info shows the PN as a 12V for 6 Cyl. Pretty nice. I didn't know about it. I don't understand this yet...
"It is in fact a 12 volt starter that would have been used with the 168 tooth flywheel ring gear, unless someone modified it to change the bendix drive for an earlier 139 tooth ring gear???"
It's a 12V starter used on 6 cyl motors. 6 cyl has a 139 tooth flywheel? So I would have thought this "special" starter would have been designed with a pinion gear that mates with a 6 cyl 139 tooth flywheel.
