some of you probably think i'm crazy but for YEARS I have used my 1/2 inch impact wrench on ALL my family cars and trucks including front and rear wheel drives. I've never had a problem getting the lug nuts off and never a problem with any coming loose. I despise having to take a 2ft breaker bar to loosen lug bolts after they dang near wring them off for safety sake. My compressor runs at the 175lbs and I use it for a lot of stuff but not for the lug nuts. I guess I just want to get something started :p about the guys that think the wheels will fall off is they don't twist the threads on the studs. This isn't to mention the idots that run the first lug up and pinch the rotor and U know what that will sometimes do! Just do it once and do it right smile
