| | | Forums66 Topics128,043 Posts1,055,609 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,763 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,763 | Instructions are OK- - - -but a short conversation with Jon (Carb King) would be much better. He usually recommends boiling the hard parts in a bath of Dawn dishwashing liquid and water, followed by a thorough hot water rinse and LOTS of high pressure air through every passageway in the carb. Solvents and "carb cleaner" sprays simply soften the crud- - - -massive volumes of air blows it away. Once the parts are surgically clean, follow the assembly instructions and adjustments to the letter. For instance, a Rochester Quadrajet has something like 22 adjustments to make during assembly, and a lot of them will have a cumulative effect on the accuracy of the next adjustment. A Rochester B or a Carter YF isn't quite that complicated, but the same principle applies- - - - -be careful, and OCD accurate! Jerry
