I have the same issue, if I get that far. I don’t think the windshield on the 41 is original; it has an aluminum frame.
I picked up the regulator, hinges, crank, and everything to make it operational.
I guess it depends on what kind of truck you want. I do believe your best option to drill holes thru and use nice hardware to make it work. But that’s just me.
~ Victor
1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery
1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD
1957 3100 - moved on
1959 C4500 Short Bus "Magic Bus" - moved on
1959 G3800 1 Ton Dually "Chief" - moved on
1958 C4400 Viking "Thor" ~ moved on to fellow Bolter
