9 members (68ironhead, Nhluvstruck, 55shaker, David Bush, MickeyP, TGP, Otto Skorzeny, treegrower, 1 invisible),
55
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2023 Posts: 190 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 190 | Thank Guys!! I got an hour to work on it today. Installed vac port in place of the plug in the intake, it’s pulling 17-18” at a high idle ( 1000 rpm? Tach install is next). The needle has an occasional flutter between 17 and 18 , so maybe I have a sticky valve. Hopefully once I get the rocker shaft all cleaned out then I can run it some more and let it work out the gunk. I have run the engine for well over an hour over several different days and it’s making 30lbs pressure so the oil has had its chance to make it up too. 2 pumps on the gas pedal and choke mostly open and it lit up in a half crank today, I’m happy about that! ðŸ‘ðŸ‘👠Post a pic 👠| | |
