Or you could just install a standard preformed steel freeze plug knowing that it will likely never rust out in your lifetime.
Yep, The first one lasted 70 plus years.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
