2 members (Greg_H, 1 invisible),
106
2
Mod | | | Forums66 Topics128,263 Posts1,058,136 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 1,294 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,294 | No crush sleeve on the H052 or HO72 Eaton. The center spacer for the pinion bearing is matched to the two bearings so that when its assembled the yoke applies force against the center race and the retainer forces the outer race against the shims in the carrier housing creating preload. The shims are used to set the pinion depth which establishes the mesh pattern with the ring gear. Backlash is adjusted using the adjusters. I strongly caution against attempting to do a rebuild without the benefit of a shop manual. Below is a helpful link: http://chevy.oldcarmanualproject.com/booklets/47stra/index.html
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | |
