0 members (),
122
3
Mod | | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,262 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,262 | This thread shows what I did to fix my deteriorated transmission mount. You need the sleeves to keep the top and bottom plate apart and ideally to keep the sleeves (with bolts or rivets securing top and bottom plates together) centered in those oblong holes in the center plate. That's why I used the liquid polyurethane stuff.
