1 members (UtahYork), 80 guests, and 2 robots.
Topics128,049
Posts1,055,637
#1520836 10/07/2023 2:53 PM
Replacing pads on mount. Are these tapped? Or do I remove and just replace with bolts. Thanks.
Both pads placed onto studs?
Family truck 1953 1/2 ton w/216
weewilly,
From what I know, that rear mount was originally riveted together.
You will need to cut-off or drill those out and use bolts and nuts to reassemble.
Might suggest using "nylock" self-locking nuts for reassembly.
~ Dan
1951 Chevy 3 window 3100
AD Addict & Tinkerer
Dan is correct that the original mount is riveted. My mount is a repo and is riveted so as Dan suggested, drill out the rivets and use bolts. I’ve included a picture.
Rear Tranny Mount
Phil
Project Journals
Stovebolt Gallery Forum
This thread shows what I did to fix my deteriorated transmission mount.
You need the sleeves to keep the top and bottom plate apart and ideally to keep the sleeves (with bolts or rivets securing top and bottom plates together) centered in those oblong holes in the center plate. That's why I used the liquid polyurethane stuff.
