The short pumps will work but the adapter plate works much better. You should use the balancer from the old 216 as the later model balancer is to big around. Drilling and taping the holes for the plate is easy just make sure to get it straight. I'm using one of these plates and 216 pump on my old doodle bug wench truck that get worked pretty hard and have never had a over heat problem.
