Dual resivior and dual boosters?... Wow, whats the GVW on that ol thing? Thats a lot of oomph!
I work with similar units on aircraft, mostly made by Bendix oddly enough, just for different systems is all. Seems to give me a little more insight into the operational design of them anyway,...
If I had to guess, & I do, I'd ask if you made sure you bled the air out of the tops of the HydroVacs where the pneumatic relay is?
Looking at how the system works, if there were a good sized bubble up there it would reduce the reaction time of the relay & thus when & how rapidly the booster engaged, hence the soft pedal into hard braking. Rust in the relay piston bore making it hang up could do the same thing.
Might also be a simple case of needing to adjust the slack out of all of the brakes & trying again. The relay piston relies on back pressure to move it, if there's too much travel in the brakes the fluid takes the path of least resistance until it builds up, so it would take more push before it moves.
Again, I'm not terribly expreinced with these old hummers, just offering my ed-u-mikat'd observations from other similar units & rebuilding my HydroVac system from the ground up.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
