5 members (NJC, Forty9, Donf, FAST55, 1 invisible),
70
2
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Welcome to the Stovebolt!
Where in Western Washington are you? Lots of Washingtonians here and someone might even be close by. I'm on Bainbridge Island but say Seattle since no one outside the area has a clue where Bainbridge is.
If the motor ran well before its likely the problem can be fixed easier than the motors can be swapped. And making it run right before rebuilding it will make getting it running again later easier. Any electrical or fuel system problem you have today will need to be fixed later too...
You don't say how cheap this other motor is. I won't pay much for something when I don't really know what it is, and don't have a use for it. But if its cheap enough you might grab it just to have the distributor and carb and things like that.
I'm beginning to run out of room to store motors so I'm getting picky about what I'll keep around here.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
