Just curious about a mark on the flywheel on the 216. I know that the timing is to be set when the "bb" on the flywheel is behind the pointer in the bell housing. That is a given. But, a couple degrees before the "bb", there is a triangle mark. What is the significance of that mark? I can't find any mention of it in the factory shop manual, and it has my curiosity up.
