2 members (2-Ton, Bill Hanlon),
82
3
Mod | | | Forums66 Topics128,142 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,078 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,078 | Are you going by the instructions in the Service Manual? It says "Brush a rubber lubricant, NO.3692455, in the grooves of the weatherstrip retainers and on the matching portion of the weatherstrip." I think you could use some liquid dish soap to lube the rubber.
