8 members (GRNHydra, Napco Man, Paul_WNC, msmall, WICruiser, Wayne67vert, Otto Skorzeny, TUTS 59),
245
11
Mod | | | Forums66 Topics128,078 Posts1,056,039 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 4,479 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,479 | Chances of finding a good 216 are slim. Even if you find one as a rebuildable core, it will be much more expensive rebuilding then getting a 235 that will bolt right in. It’s a swap that myself and many other ‘bolters have done. There are plenty of them out there and if you get a 54-55 it’s a direct swap. 56-62 would require a adaptor plate to move the water pump. I performed this installation and it was not hard at all. You’ll also gain HP. MY ‘59 235 has 135 vs the 90 the 216 it came with.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
