In the process of replacing my floor panels I eliminated the original gas pedal pivot bracket. Before I salvage it from my pile of removed scrap metal and try to determine how to connect it to my SBC Holley carburetor I am interested in what others have done.
If you stayed with the original pedal how did you connect the pedal to the carburetor/throttle body?
If you "upgraded" to a newer style pedal any insight regarding what worked for you in terms of pedal source and connection to the carburetor/throttle body would be appreciated.
