| | | Forums66 Topics128,057 Posts1,055,810 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,040 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,040 | The 48-51 shop manual says after removing the bearing retaining screws from the differential housing, "tap the splined end of the propeller shaft allowing the pinion shaft to slide out."
The 1/2 ton torque tube axles were pretty much the same up thru 55, with only minor changes. So you should be able to drive the shaft out from the transmission end. I would use something relatively soft (a soft faced hammer or wood block) to prevent damaging the splines.
