3 members (TexasJim50, baldeagle, 1 invisible),
77
3
Mod | | | Forums66 Topics128,018 Posts1,055,340 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | The master cylinder if it’s in proper working order will not trap air it will bleed fine on the truck The factory did not have to bench bleed before installing There are two holes in the master to the reservoir so that airlock cannot happen One hole is very small less than 1/16 it’s just a bit larger than a needle With that second hole clear you won’t lock air The designers would not have made a product that couldn’t be installed dry and bled in place Bench bleeding is an urban myth that can damage the master if you over travel it a fraction too much I’ve installed these dry (lubricated) on my truck and they bleed just fine by hand with two people doing it the old fashion hard way.
Over traveling the master piston too deep will damage the rubber cup and it will be wet on the piston plunger end forever and need periodic fluid cap up Really over-travel it and you could damage the residual pressure check valve in addition to damaging the cup -s | | |
