| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2022 Posts: 4 'Bolter | | 'Bolter Joined: May 2022 Posts: 4 | I have a 1937 GMC Model T14B. The wheels are 6 lug.
1) Does the "B" in the model number indicates that it is a 126" wheel base? Or, does the "B" indicate something else?
2) The chassis number is metal stamped into the data plate (positioned center on opposite firewall side; inside cab) and also stamped on frame on passenger side slightly forward of the RF wheel.
3) The chassis number is: 21333
4) The engine number (stamped on the horizontal surface of the metal pad, front left of the head) is: F616294
Any assistance with this would be appreciated.
Thank you. | | |
