5 members (Phak1, tclederman, Charles in CA, wvstovebolt, 1 invisible), 210 guests, and 4 robots.
Topics128,083
Posts1,055,967
Members48,430
I have a 1937 GMC Model T14B. The wheels are 6 lug.
1) Does the "B" in the model number indicates that it is a 126" wheel base? Or, does the "B" indicate something else?
2) The chassis number is metal stamped into the data plate (positioned center on opposite firewall side; inside cab) and also stamped on frame on passenger side slightly forward of the RF wheel.
3) The chassis number is: 21333
4) The engine number (stamped on the horizontal surface of the metal pad, front left of the head) is: F616294
Any assistance with this would be appreciated.
Thank you.
Crusing in the Passing Lane
GMC should have an Olds or flathead Pontiac engine, engine SN should be stamped on machined surface near rear of engine, might be 230xxxx or some such. Chevy engine now.
Ed
