| | | Forums66 Topics128,115 Posts1,056,636 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 1,991 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,991 | I looked at the Cole Hersee 24023 and the 24059, they are not a latching relay, you have either a bad relay or the signal wiring is keeping it energized, check for voltage at the small studs after you turn the key off-should have no voltage there.
1957 Chevrolet 5700 LCF 283 SM420 2 speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto, 1978 Yamaha DT175, 1999 Harley Davidson Softail Fat Boy
Entire Thread
Key off, starter motor continues to run
| Dixon | 04/19/2022 8:14 AM |
Re: Key off, starter motor continues to run
| 78buckshot | 04/19/2022 10:01 AM |
| Bill Hanlon | 04/19/2022 1:01 PM |
| 78buckshot | 04/19/2022 1:05 PM |
| Dixon | 04/19/2022 1:43 PM |
| Hotrod Lincoln | 04/19/2022 3:11 PM |
| crenwelge | 04/19/2022 8:36 PM |
| 78buckshot | 04/19/2022 9:48 PM |
| Dixon | 04/20/2022 5:06 AM |
| Hotrod Lincoln | 04/20/2022 5:22 AM |
| Dixon | 04/20/2022 6:03 AM |
| 78buckshot | 04/20/2022 12:00 PM |
| klhansen | 04/20/2022 5:51 PM |
| Hotrod Lincoln | 04/20/2022 6:33 PM |
| Dixon | 04/21/2022 5:56 AM |
| Dixon | 05/02/2022 4:50 AM |
| Hotrod Lincoln | 05/02/2022 5:53 AM | |
