0 members (),
44
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | What Fibonachu said, but you may want to remove the bondo as well. I got a replacement fender that had some up near the headlight. I removed it down to bare metal and fixed the distorted part with hammer and dolly, I don't think that area will need more that a skim of filler or maybe just some high build primer.
You can check for bondo with a magnet. If there is very much the magnet won't stick to the surface.
If the paint is well adhered you can just sand it to feather edges and primer and paint over it.
