| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | My '42 crank did not work too well, so I removed it and had a machinist friend take a look at it. The steel shaft goes through the aluminum body of the mechanism and one hole was wallowed out as you describe. He enlarged and rounded the hole and made a bushing to fit and now it works fine. If the gear teeth are worn badly you may still have problems but in my case the bit of wear is not fatal yet. Kent | | |
