2 members (GRNHydra, Peggy M),
90
2
Mod | | | Forums66 Topics128,060 Posts1,055,837 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | relays are all about the amp draw. and what wires you are running like up your steering column. a relay draws maybe 1/4amp to activate the switch or less therefore you can run much smaller wires up the column. Horns draw from a few amps up to 24 or more therefore you need much bigger wires. Longer wire runs mean larger voltage drops. Not a big deal for a horn but other systems it becomes a issue.
Engineers put relays in for a reason not just to add more parts. Look at your whole layout if the switches and wires are all large enough to hand the full loads through the circuit a relay may not be required. But if that ground wire up to the horn switch is small then pull a new wire or run a relay. | | |
